LOLz... I found my fixit list from when I first bought my S4
To fix:
AC drain is clogged
Left signal blinks fast
Adjust doors
Cracked windshield
Missing headlight washer covers
Staple shift boot
Brake pad warning light
Belly-pan
Glovebox light
Take Vivian Out
Bomb
Paint
Cracked clearocat on stock wheels
1 broken headlight tab
Oil filter bracket leaking
Small Parts
Fuse puller
Washer + Bolt for coil pack panel
Floor mats
Trunk carpet
IC shroud
Trunk storage container brackets
Relay panel cover
Fixed:
Replaced right front lower door moulding
Replaced reverse light socket
Bought CD changer
Replaced damaged clamp on michelin man hose
Stripped and painted under-headlight trim
Clamped loose hose on moisture trap
Got alignment done
Replaced left front tie rod end
Replaced right front tie rod end
Replaced left rear tie rod
Painted front bumper
Painted rear bumper
Replaced torn michelin man hose
Painted hydraulic/alternator mount
Replaced leaking X plug in hydraulic pump
Replace brake fluid
Replaced catalytic converters
Replaced hood cable
Replaced timing belt
Replaced timing belt roller
Replaced serpentine belt
Replaced water pump
Replaced thermostat
Flushed and replaced coolant
Tightened steering damper
Replaced transmission fluid with Redline MT90
Replaced rear differential fluid
Fixed passenger footwell light
Replaced passenger door lock
Repaired broken tab on crossover tube
Replaced leaking headlight washer hose
Bought new oil pan plug
Painted diff lock button
Repaired broken headlight tabs
Bought and installed belly pan bracket
Removed rust from cylinder-head heat shield
Bought speed nut to secure centre console
Installed missing knee-bar bolts
Installed parking brake circlip
Bought screws for rear seat
Replaced fuzzy RF Bose amp
Replaced broken rear Bose amp
Bought IR key
Repaired broken hood light
Bought missing radiator support to body bolts
Replaced broken bumper clip
Polished exhaust tips
Replaced both parking brake cables
Replaced parking brake handle
Bought three lower grill pieces
Removed trailer hitch
Fixed rear window/lock lockout switch
Bought battery
Replaced fuel filter
Replaced valve cover gasket
Replaced coil pack end plug
Bought battery hold-down
Bought Instrument cluster screws
Replaced broken sunroof switch panel
Replaced passenger seat switch
Replaced broken passenger side mirror housing and glass
Replaced driver's seat switch
Fixed passenger map light
Fixed rear left passenger map light
Fixed rear passenger window switch
Replaced stripped bolt in seat rail
Fixed broken wire to front left Bose speaker
Replaced broken gas pedal
Fixed non-functional left power-mirror
Replaced yellow auto-check bulb
Replaced driver's door lock
Replaced ignition lock
Fixed wiring under seat
Replaced trunk lock
Bought spare tire and tools
Bought seat rail trim
Replaced siezed hood pin
Replaced oxygen Sensor
Replaced air filter
Replaced broken rear license plate speed nuts
Replaced both rear calipers
Painted both rear calipers
Painted both rear brake discs
AC drain is clogged
Adjust doors
Cracked windshield
Staple shift boot
Belly-pan
Glovebox light
Take Vivian Out
Bomb
Paint
Small Parts
Fuse puller
Floor mats
Trunk carpet
IC shroud
Relay panel cover
Fixed:
Bought CD changer
Got alignment done
Painted rear bumper
Replace brake fluid
Replaced hood cable
Replaced water pump
Replaced thermostat
Bought IR key
Bought battery
Replaced trunk lock
Replaced air filter
I gotta say, that car looks SOOO much better now. Night and day difference. You've put a lot of money, blood, sweat, tears, etc into it!
It's nice to see when they end up nicer than when they started!
