Tachometer no worky..
I swapped my speedo yesterday due to the flaky ODO with a new used unit. Removing the cluster and swapping is actually not that bad. Anyway, I got everything back together and started the car but the Tacho was not working. So I unplugged the ECU for about 20 minutes and plugged it back in. The Tacho worked. But then I got the idea from URS4.com about swapping bulbs with the 2W one so I removed the cluster again and away from the car to swap all bulbs. When I put everything back togeher, Tacho no worky again. hmmmm! so I unplugged the ECU again with the same routine earlier but this time, Tacho still not working..
And also, i got this oil signal or something blinking right in the middle of cluster..
Any ideas?
Any ideas?
Ante Ujevic (02-29-2020)
DeividasJ
05-26-2015 11:03 PM
datsun2k
11-24-2010 07:37 AM
QPower95
05-30-2010 07:20 AM
