Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Where is the oil temp sensor? Bentley only shows an oil switch and oil pressure sensor. I have ...
Old 01-19-2008, 04:44 PM
SCL
SCL's Avatar
Default Where is the oil temp sensor? Bentley only shows an oil switch and oil pressure sensor. I have ...
never seen the oil tempurature gauge work in the 8 years I've own it. It's a 95 BTW.
Old 01-19-2008, 04:48 PM
UrS4boy's Avatar
Default Down on the oil pump IIRC. You need to remove the belly pan. Its not to far from the oil filter but
on the oil pump. I am surprized that Bentley doesn't show it on the oil pump location diagram.
deephouse's Avatar
On the oil pump.
deephouse's Avatar
argh you got me by 10 seconds. you're fast!
Old 01-19-2008, 05:00 PM
UrS4boy's Avatar
Default For the too slow (Brian), its on the oil pump as shown in the photo inside and the Part No is...
<center><img src="http://pictureposter.audiworld.com/15624/oilpump1.jpg"></center><p>
035 919 521B, ref: KATE (what a good girl), A10Q, MG 9 (electrical) SG 19, Ill. 919-65, List Item 20.
Also on MG 1 SG 15 Ill. 115-30, Item 6 = plug for AAR (2.3 L 10v NA we didn't get in North America) pressure relief valve BUT for AAN No. 6 = 035 919 521B oil temp sender for gauge.
Come on Brian, get with the program.
&lt;kidding&gt;
Old 01-19-2008, 06:12 PM
deephouse's Avatar
I was absent the day they tought AAN Oil Pump section!
Old 01-19-2008, 06:28 PM
UrS4boy's Avatar
Default It was a tought day when we taught AAN oil pump 101.
Sorry Brian. It was just there.
You know that I'm only kidding, right?
I just have a lot of info at my finger tips and my memory is still working.
SO far. So far.
"HAL: Hey, Dave, what are you doing?
BOWMAN WORKS SWIFTLY.
HAL: Hey, Dave. I've got ten years of service experience and an irreplaceable amount of time
and effort has gone into making me what I am.
BOWMAN KEEPS PULLING
OUT THE MEMORY BLOCKS.
HAL:..."Daisy, Daisy, give me your answer do. I'm half crazy all for the love of you..."
(HAL 9000, 2001 Space Audissey)
SCL
SCL's Avatar
Default Ah, now I see. Must be difference in year model - Bentley calls it a "Pressure relief valve", but...
then if I read below, it describes it as "Threaded plug with engine oil temperature sensor for oil temperature gauge."
I didn't notice it on the diagram until I read your reply. It's drawn like a bolt with a sleeve or something.
On the left side of the block the diagram has one called "oil pressure switch (white)", which has a single electrical connection, and anohter one called "Engine oil pressure sensor." Mine is missing the Engine oil pressure sensor. In place of it is a steel allen head plug. I guess now I know where I can connect a pressure sensor/gauge if I ever wanted one. ;-)
Thanks for the reply. ...It will be nice to see that temp gauge actually do something...that is if I can fix it.
Old 01-19-2008, 06:47 PM
UrS4boy's Avatar
Default The S6s did not get an oil pressure sender but I think they got a oil temp sender. You can't be enti
rely wrong about the pressure relief valve part of the equation. From the looks of that "exploded" oil pump, the temp sender looks like it has two functions, one holding the pressure relief valve and spring in place and two, providing a temp signal to the instrument cluster.
Old 01-19-2008, 07:13 PM
deephouse's Avatar
Of course!
Quick Reply: Where is the oil temp sensor? Bentley only shows an oil switch and oil pressure sensor. I have ...
