Anyway to unlock the car from inside the trunk? my doors are locked but my trunk is open....
im already having a bad day, at least my cars in the drive way, dont ask how the keys are inside... Thanks, i STFA, i didnt see anything, im hoping i can set off the pump from the trunk mechanism?
I thought about going through the ski bag, but even if i cut through it, i cant reach the door lock anyway.
Probably - See inside where I guess how it can be done
If you turn the trunk key to the left two times quickly it will unlock all of the doors. You can probably simulate this by removing the trunk cover liner and finding the linkage from the lock to the mechanism. Remove the clip that attaches the connecting rod to the lock cylinder and trigger it twice in succession.
I have never tried this but I think it should work.
Good Luck.
Good Luck.
HAHA!! GOT IT!!!!!!! yesssssssss
It didn't take me that long at all, if i was to do it again, it would be a 15 minute job. After taking off the panel in the trunk i realized it was sending an electrical signal when you turn the key twice, it wasn't moving a mechanism. i saw a connector going to the key cylinder, took off the connector, its a 3 pin, jumped the pins and got it right the first time, and the car unlocked! thanks for the help!
