Audi R8 Discussion forum for the Audi R8 and its variants
Dead clutch pedal R8
Old Jun 13, 2012 | 01:21 PM
tactiks4's Avatar
Default Dead clutch pedal R8
The first gear and reverse gear does not go in properly in the morning, after we pump up the clutch 10 times it goes in well. There seems to have oil on the rubber of the master cylinder on the window of the transmission. The car isn t covered under warranty anymore and there is 74 000 miles. Do you think the engine has to be removed to do the job or just inclined to remove the transmission? Also is it recommened to change the slave cylinder? How much could Audi charge to have this done? Any help would be apreciated
Old Jun 13, 2012 | 05:13 PM
ryan_qttro's Avatar
Remove rear bumper, pull trans out. Do not have to pull motor, might as well replace slave cylinder while you are in there.
ac921ol
9
Nov 1, 2007 11:33 AM
Beeman'S4
9
Oct 4, 2006 08:23 AM
Shadowfax
Oct 14, 2005 11:17 AM
Dr. Bondo
9
Dec 16, 2001 06:10 AM
BO
Aug 30, 1999 06:05 PM
