Adding a sub to stock stereo
Old Apr 20, 2001 | 10:47 AM
RedBlackYellow's Avatar
Default Adding a sub to stock stereo
What is the easiest way to get the stereo to put out rear L&R RCA's to wire to an amp? I have heard some people connecting via the rear speakers, but does the back of the stereo already have RCA's? I haven't pulled out the radio to look at the back yet, so just curious on other's ideas for wiring.
Old Apr 20, 2001 | 12:40 PM
GPO - Needs a car!'s Avatar
Member
Default I have a '96 A4 and would like to add a sub too...
I have the stock head unit and the cd changer. Can i add a sub easily? I just want a small 8 or 10 inch sub to fill out the sound a little more.
Old Apr 24, 2001 | 01:10 PM
JoeBoxer's Avatar
New Member
Default Re: Adding a sub to stock stereo
There is NO RCA at the back of the Stock Stereo. The pre-amp out is just a set of wire that runs out of the deck to the amp located at the speakers. You can wire-up a Set of RCA, but that would only be useful if you are adding amps to the components. For a sub, the best thing to do is add a parasite RCA to the pre-amp wire at the back speakers. I would also recommend hooking up a ground-loop filter once you do that just in case, but before getting the ground loop, just test it out without it and see how it sounds. If you get noise, then you'll need it, if not, then thats all good, and your set.
Old Apr 27, 2001 | 10:15 AM
Toro996's Avatar
New Member
Default Re: I have a '96 A4 and would like to add a sub too...
just use a line to rca converter for the signal from the rears and run the rest of the wires as you would in an aftermarket stereo. Power, ground, and the remote on/off wire for the amp. hook up rca's from the amp to the converter, and outputs of the amp to the sub. If the amp is bridgebale, bridge it to get more power to push your sound.
stealth162
Jul 1, 2008 02:31 PM
Jerseycq
9
May 11, 2007 09:34 AM
DCO007
Jan 7, 2005 06:50 PM
COT51E-ukcab
Dec 30, 2002 11:14 AM
tgray
Jun 28, 2002 06:57 PM
