Aftermarket headunit and antenna problems
Old Jan 30, 2010 | 11:41 AM
SlickNogaro3's Avatar
Default Aftermarket headunit and antenna problems
I have a 2000 S4. I swapped out the factory headunit with with the Pioneer avh-p3100. Everyting works great but I get no FM radio reception. The AM radio works but not very well which it never really did. I ordered wire harnesses and they gave me an antenna adapter which hooks up to one of the wires. There is another wire that is not hooked up. Could this be a seperate one for the FM radio? Any help is greatly appreciated.
Old Feb 24, 2010 | 12:36 PM
EuroFreak's Avatar
Since the radio antennas are in the rear window, there may be an RF amplifier that needs to be powered on with the radio. I'm not sure but I do know some cars are like this. This could be one thing to investigate.
Since I have my rear deck panel removed at the moment I can see that there are two modules right under the rear window which are likely to be the interfaces for the antenna(s). They are either signal amps and/or transformers to correct the impedence of the antennas.
Based on the coaxes that I saw on those interface modules, I believe you may not have the FM lead connected. I'm curious to see how the antennas are set up in the B5.... do you have a Bentley manual?
Old Mar 4, 2010 | 07:11 PM
Sorry for the late response. I have been without my S4 for about a month and just got it back. No I do not have a Bentley manual. So do you think that I may just need to connect another wire to power an amp for the antenna?
Old Mar 4, 2010 | 07:14 PM
I am probably going to dig into it again this weekend and see what I can find
grillage
Jun 6, 2011 05:42 AM
shapiror06
May 30, 2006 10:00 PM
750NighthawkS
Jul 30, 2005 04:04 PM
Maxster4.2
Feb 16, 2004 01:06 PM
imports only
Jan 16, 2003 12:47 PM
