Another amp problem
Old Feb 12, 2005 | 11:47 AM
starting ...'s Avatar
Default Another amp problem
I have a sony xplod amp which is 3/4 channel. My sub is connected to the rear speakers using both the left and right speaker terminals. My sub works fine except it can not be controlled by the sub woofer level on the headunit. The rear speakers will not work. They are hooked up to the front speaker terminals. They will work if i disconnect the sub and hook them to the rear speaker output. The rca terminals are hooked to the correct inputs.
Old Feb 12, 2005 | 02:53 PM
turbo_flipper's Avatar
Member
Default what model head unit do you have?
also, how are your front's powered? do you mean to say that your fronts and rears are running off the same 2 channels?
as for the sub, my first guess would be that your head unit has dedicated sub-outs, which aren't being used to send signal to the amp. therefore, when you adjust the level, it doesn't alter the output of the rca's that are actually sending a signal to your sub
Old Feb 12, 2005 | 03:11 PM
Default my fronts are powered off the headunit
the headunit has subwoofer pre-outs and also rear speaker pre-outs. I had it wired once the same way as now I thought and the adjustment for the sub worked through the headunit.
Old Feb 12, 2005 | 09:13 PM
bbaudi382's Avatar
Default no, just connect your sub wires to the amp and dont use the rear channel
your sub channel has to be connected for it to wokr.
Old Feb 13, 2005 | 04:44 AM
i'm using the rear channel for the sub and front channel for the rear speakers
Old Feb 13, 2005 | 11:56 AM
Default got it fixed. switched the rca cables and it works. seems like they are backwards though
its weird
Must Have RS6
May 25, 2004 07:41 AM
kazino21
Audi A3 / S3 / RS 3
Dec 21, 2002 09:44 AM
tgray
10
Jun 24, 2002 10:00 AM
SurfinSilly
Oct 1, 2001 05:18 PM
Kyle K: TampaS4
Apr 2, 2001 05:52 PM
