B/O sub upgrade and possible amp configurations
New to Audi -- Just got an 2013 S4. Wow.
Coming over from a 335 where I had a pretty strong audio set up (JL/700/5 driving morel dotecks in the doors -- channels 1-2, 8inch audio systems under the seats (set up as true woofers -- passed them signal from 80-200Hz) -- channels 3-4 and a JL 10w3V3-4 in a custom sealed enclosure driven by the sub channel.
I have the B/O system and it is pretty good. Actually, the imaging and the mid bass and up is actually better than the above system --- pretty sure it has to do with the amount of signal that I was driving up from the floor. That said (and I have seen it in this forum before) the low end is not too strong. Thus, I will be adding my current amp and possibly the sub (if I can get Wicked CAS to make a right side enclosure to hold it) or one of the JL audio microboxes.
The above is all background to my specific question: what should I do with the B/O sub?
One option is to just delete it. This would have it function (I'm guessing) as a passive resonator indirectly driven by the sub in the trunk into the cabin.
Another is to drive it the B/O sub bridged with channels 3/4 of my amp. I have seen in one thread that the B/O amp drives 150 watts into the 8ohm woofer. The JL drives 75rms/channel-- 150 bridged but this is into a 4 ohm load. Is this going to fry that woofer?
Still another is to let the B/O amp drive the B/O sub and just tap the signal and drive the new sub with my amp. My fear here is that I may get phase differences but I'm pretty sure that I'm overthinking this issue.
Neither of these are particularly complicated as long as I turn off the filtering in channel 3/4 -- it has the option of being high pass or band pass. But suppose I get fancy and turn on filtering....
Another choice is to repurpose the B/O sub to be a true woofer and pass it from 80 to 200 or so. If I do this I can use either the B/O amp sub outputs for the input into this channel or I could look for a full range signal -- just not sure which wires to tap.
By my count there are about 10 different questions above. Any advice on any of them greatly appreciated.
I would probably just leave the factory components alone and add a subwoofer if you feel more bass is needed.
If you encounter phase differences while running an additional subwoofer, there should be a phase switch on the amplifier or you can simply wire the sub deliberately out of phase. I don't think this should be a huge concern.
