Coding or totally incompatible?
I've got used 8T1035223A, it's not mentioned to be compatible, but all connectors are the same.
So far, MMI starts, but there is no sounds, sound icon muted, no reaction to volume control.
As far as i know when there is component protection, it should work, just sound only on left side.
So is this totally incompatible, or other actions required to make it work?
VCDS - Sound System
That all said, 8T1... is not even for B8.0 years, 2G or 3G. That's a B8.5 amp. The B8.0 3G B&O amp is 8T0 035 223 AN.
Also note, the DSP parameters data set is loaded into the amp unit. So unless you can confirm the amp came from another S5 coupe, you'll want to be sure they load up the correct data set for your VIN when they do the CP reset.
