Custom installation...
Old Apr 16, 2004 | 07:18 PM
CusTTom
Elder Member
Default Custom installation...
Some pics of the install... in progess.. final pics to come tomorrow.. just a taste...
The Enclosure:
<img src="http://pictureposter.audiworld.com/73982/19109225989.jpg">
YES... that IS Alcantara on every panel in the back.
<img src="http://pictureposter.audiworld.com/73982/19109316101.jpg">
Hard to see, but a digital Voodoo readout for the 0 gauge power wire.
<img src="http://pictureposter.audiworld.com/73982/19109371525.jpg">
The back.... all custom made welded brackets... pics of the fiberglassed cover to come tomorrow.
<img src="http://pictureposter.audiworld.com/73982/19564075269.jpg">
<img src="http://pictureposter.audiworld.com/73982/19564264453.jpg">
Many thanks to Design Tech, in Union, NJ.. these guys are the most awesome installers ever. You want it done right.. gotta go to them.
I can't even get into what went into this car.... the full writeup will come tomorrow...
Well let's begin here.
There is an Eclipse 8053 headunit which puts back 16 balanced volts across balanced lines to Eclipse's balanced line convertor which feeds the amps a super clean 8 volts.
From there for the main 4 channels... there is an Arc Audio 4150CXLR which puts out according to them 85x4 RMS.. but that is extremely underrated, and the amp gains are at 0.. completely turned down.
Same goes for the gains on the 2500CXL which is putting out 525x2 RMS (again underrated) to each Eclipse Aluminum DVC 10" subwoofer mounted inverted in a fiberglass and wood enclosure, covered in Alcantara. Each amp is mounted on custom fabricated metal bracketry.
Between the two woofers, on an inset aluminum plate, sits a 5 Farad Soundstream Capacitor, which receives it's power in from a 0 gauge power wire, which has also ran through a Voodoo digital power readout, where the old CD changer was. Power goes from there to a distribution block, where each amp is fed a 4 gauge power input. The capacitor actually reads out voltage also, and lights up to the power draw (didn't think the lights changed originally.. will have to decide on that one to come).
What you don't see, is the wood and fiberglass amp surrounds, which covers the whole rear area, covered also in alcantara. The side panels have had the vents filled and smoothed, and have been covered in alcantara.
Old Apr 17, 2004 | 01:20 AM
ben gt/cs's Avatar
so nice man. great job
Old Apr 17, 2004 | 04:40 AM
CusTTom
Elder Member
Thank you
Old Apr 17, 2004 | 02:20 PM
turbo_flipper's Avatar
Member
Very nice...must sound amazing
Old Apr 18, 2004 | 06:47 PM
CusTTom
Elder Member
Default Thanks.. it does...
The car is really loud and clean. It will probably be in Design Tech's booth at Waterfest. But otherwise you'll be seeing it at the shows and competitions.
Old Apr 19, 2004 | 05:44 AM
dragon-ryder's Avatar
sry man but you need to clean your wires up more
Old Apr 19, 2004 | 07:08 AM
CusTTom
Elder Member
They are now... that pic was still in progress.
Old Apr 19, 2004 | 11:56 AM
Lightweight-USPowah's Avatar
Default How is the shop going to setup the amp rack? Are the amps
going to be completly hidden?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 19, 2004 | 01:57 PM
CusTTom
Elder Member
Default The amps will be showing... the amps are mounted on custom made metal brackets
which serve as pedestals for the amps. The main cover piece has cutouts for the amp faces to show through.
kiNGMak.:.OEM
Aug 22, 2005 10:19 AM
CusTTom "Quag" WesTT
Apr 16, 2004 07:35 PM
NY / NJ / CT Discussion
Apr 16, 2004 06:38 PM
