Install problems...
First off, the open grommet in the firewall I planned on running my power wire through wasn't open...someone used it on their 02 but my 03 has a tube from the brake fluid reservoir going through it. I couldn't find another opening so I ran the power from the trunk to the driver kick panel for today. Second, not gonna be running new speaker wire into the doors like I had planned...as someone else had also done to all 4 doors. I got the kick panel off and I don't have the same space under the wire harness that they used. I figure I'll just splice into the speaker wires from my bose amp in the trunk...why run new wire to the front only to splice into the factory stuff anyway...save myself some frustration. Last issue...when I got the Symphony II out the spot for the Blau adapter is already being used...pre-outs for the Bose amp I suppose. Not sure what to do here yet...I was going to run my Stinger Dream Series signal cables to the trunk but I'm seriously considering just tapping the line levels from the amp also. I'd like to keep the factory rears working for fill. Is this where people talk about re-pinning the factory harness? Would I just repin the harness with a single set of RCAs from the Blau adapter and run my interconnects? Running the power wire was such a serious b*tch that I'm not sure I want to run more wire up the other side...the easy way out is looking better all the time. I can't imaging It'd make a significant difference in sound quality. Maybe I'll just suck it up and run the wire and figure out how to hook everything up later...maybe have a shop make the connections and see if they can get the wires into the doors. Any input/suggestions?
It was a pain in the *** to back the pins out, but i finally got them. Just replace the pins in the HU connector with the Blau pins, and you should be good to go.
It made a world of difference in the sound - I had been running through a line level convertor.
Good luck.
