Install question
Old Mar 16, 2004 | 06:20 AM
FormrJeepr's Avatar
New Member
Default Install question
Can anyone tell me whether this stuff will indeed fit a 2000 A4? Particularly facia adaptor and wiring harness<ul><li><a href="http://www.caraudiodirect.co.uk/default.php?cPath=292_294_339">http://www.caraudiodirect.co.uk/default.php?cPath=292_294_339</a</li></ul>
Old Mar 16, 2004 | 07:14 AM
Perpetual Novice's Avatar
Default None is needed unless you change your audi system.
the fascia adapter compensates for the fact that most head units are DIN sized, while the audi head is bigger. I'm not sure if that is the right adapter for your year thought, you have the symphony radio, right?
The speaker adapers let you run 5.25" drivers in the stock 4" door locations
the wiring harness would be needed if using the stock head unit with aftermarket amps and speakers
Tell us what you are planning to do, we'll tell you what you need
Old Mar 16, 2004 | 07:52 AM
FormrJeepr's Avatar
New Member
Default Re: None is needed unless you change your audi system.
I plan on upgrading the headunit to a single DIN Blaupunkt and adding an aftermarket amp and a sub.
Old Mar 16, 2004 | 10:33 AM
Default Some answers
You'll need an aerial adapter to use the stock antenna with the aftermarket head.
The fascia adapter is just a set of plastic spacers to go from &lt;1999 Concert style head to single DIN, I don't think that'll help you. search here, I think most people end up making a custom panel to fit.
You'll need some kind of wiring harness that plugs into the stock wiring harness to get power, etc.
You're not using the stock speakers are you?
Old Mar 17, 2004 | 06:29 AM
FormrJeepr's Avatar
New Member
Default Re: Some answers
I was going to continue using the stock speakers for now and swap them out at some future date
Old Mar 17, 2004 | 12:14 PM
The Seed's Avatar
New Member
Don't forget - Get the antenna adapter that has a power lead! Otherwise reception will suck and yes adapters are widely available for the wiring harness.
Old Mar 18, 2004 | 06:09 AM
It's your car, but the worst part of the stock system is the speakers
Old Mar 18, 2004 | 11:36 AM
FormrJeepr's Avatar
New Member
Default Re: It's your car, but the worst part of the stock system is the speakers
I did some more research, I think I'm gonna go with Infinity Kappas front and Rear with the rears running off a separate amp. Kappa 6.5"s push 75W RMS, any recommendations for an amp? I am currently looking at a Phoenix Gold pushing 75W RMS x 2
 Michael S. Palmer
Old Mar 18, 2004 | 12:46 PM
Default Sounds like a good plan to me
Another amp you might look into is PPI, they're pretty nice and not incredibly expensive.
AndrewWK
Audi Original "S" Cars
22
Aug 10, 2015 12:05 AM
Ryanic
Jun 11, 2013 06:33 AM
scottmcc8audia4
A4 (B7 Platform) Discussion
Jan 31, 2006 06:39 AM
gtreng1
May 17, 2005 11:10 AM
mtu_audi
Dec 9, 2003 10:09 PM
