Multi-component integration...
Old Feb 12, 2006 | 06:00 PM
Sleeper1.8T's Avatar
Banned
Default Multi-component integration...
Hello all,
Just curious if anyone knows if there is a way to integrate both an XM and an iPod Nano into the stock head unit. Just not sure if they use the same connectors or not. I emailed Blitzsafe too, but thought I may get a quicker reply from you guys. TIA.
Old Feb 13, 2006 | 05:04 PM
NSX JR's Avatar
Default Yes, you'll have to get a "SAT" ready headunit, sat module, ipod interface...
then do some special wiring yourself. Here's the tricky part...
The audio from the SAT tuner goes to the headunit audio input.
The audio from the ipod interface goes to the audio inputs on the SAT tuner.
Easily done.
Old Feb 15, 2006 | 07:33 AM
TeddyBGame's Avatar
Default If you don't add the OEM Sym II with SAT button...you can always just...
use this switching device between your aftermarket XM tuner and ipod nano.
Bottom line:
1) Sym II with SAT button, OEM XM tuner and ipod nano via icelink/audi ipod adaptor is very doable...but will probably cost you about $600+ in parts. On the plus side, the integration, look and feel will be well worth the $$.
2) Existing Sym II without SAT button, aftermarket XM tuner and switching device...some RCA cables...and you are in business for about $200. Your dash will be a bit cluttered...so you'll have to be creative on where you locate your nano etc.
do a search in this forum...as this question comes up a lot.
Good luck!!<ul><li><a href="http://www.logjamelectronics.com/auxaudi.html">http://www.logjamelectronics.com/auxaudi.html</a</li></ul>
cyron
Jan 3, 2007 09:13 AM
paulroad
Dec 15, 2005 11:05 AM
modwad
13
Jun 2, 2004 03:11 PM
2000SantorinS4
May 17, 2002 06:29 PM
Dimitris
Dec 21, 1999 02:07 AM
