Radio Code
Press FM2 and RDS simultaneously and hold them down until "1000" appears on the display, then release them.
Do not, under any circumstances, continue holding them down or press them once again. This would cause the number"1000" to be the input code number."
Use the first 4 (left to right)station buttons to change the correponding digits to your code.
Press FM2 and RDS simultaneously again holding them down until SAFE reappears.
Release.
Incorrect code number
If an incorrect code number is entered inadvertly when cancelling the electronic lock, the word "SAFE" appears in the display - first flashing and then continuously.
You can now repeat the entire cancelling proceedure ONCE MORE. The number of attempts will be shown in the display.
If an incorrect number is entered once again your radio will be locked up for approximately one hour. The radio will not play.
After one hour has passed-the unit must remain turned on and the key must remain in the ignition-the numbe rof attempts will stop being displayed and the electronic lock can be cancelled as described above.
The cycle - two attempts,one hour lockup - still applies."
