weirdness here
Old Apr 10, 2004 | 06:06 PM
runoverb4's Avatar
Junior Member
Default weirdness here
I hear a noise every so often out of my passenger side speaker. Im running a pioneer head unit amplified by nakamichi. This noise, which is just static and the music, will come out of nowhere while playing my stereo. I turn the head unit off, and it goes away for a while. any thoughts on what the heck is causing this?
btw i also have an optima yellow top in the trunk and a 5 farad cap
Old Apr 11, 2004 | 12:11 PM
MacSub's Avatar
Default I'd check your RCA's
Sounds like one of them is on it's way out. I had this on a recent install with a brand new set of expensive leads. Sounded like detuned radio. I'd check this first before looking at the components. Just switch the left and right RCA's over and see if the problem switches as well.
Old Apr 12, 2004 | 06:39 PM
runoverb4's Avatar
Junior Member
You think thatd happen with a pair of brand new tsunami's?
Old Apr 13, 2004 | 01:28 AM
MacSub's Avatar
Default Anything's possible
It's the easiest thing to check and eliminate before you look at the other components. You'd be kicking yourself (like I did) if it was the last thing you check.
Old Apr 13, 2004 | 11:11 AM
runoverb4's Avatar
Junior Member
Default i dont think its the rca's...
when i turn off my head unit, ie no signal going through the rca's, the noise is still there for a few seconds until the amp turns off, thats why im thinking its the amp itself.
Old Apr 20, 2004 | 12:24 PM
MacSub's Avatar
Default If the amp is still powered then it will still pick up a short
in the RCA's. If you think it's the amp, then surely eliminating the RCA's first is slightly easier than pulling out the amp.
DoubleA4
Audi allroad
Apr 18, 2013 09:24 AM
masq
10
May 31, 2007 12:18 PM
slimcubby
9
Jun 14, 2005 12:41 PM
8poh
Dec 21, 2001 12:51 AM
EricW
Feb 26, 2000 10:33 AM
