Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
Applying or Removing with a Buffer?
Old Nov 6, 2003 | 06:55 PM
armoredsainTT's Avatar
Default Applying or Removing with a Buffer?
Do you use it for applying and removing polish and wax, or just either applying or removing? I am seriously thinking about getting a buffer.
Old Nov 6, 2003 | 08:24 PM
Troy H's Avatar
Applying all products but wax. Wax gets applied by hand. All products get buffed by hand.
Old Nov 7, 2003 | 12:40 PM
Default That's a good point, thanks Troy. I'm thinking about the PC 7424.
I like how you have options with different pads and etc. Do you recommend foam for the polish?
Old Nov 8, 2003 | 05:26 AM
Al Pollack's Avatar
Default Try a PC 7424 You'll never go back ..
The PC's are foolproof. For removing compounds/polish's, it's the only way to go. You'll have less work AND better results. There's some excellent information on the properautocare website.
Al ..
Old Nov 10, 2003 | 06:19 AM
SportsCarCare.com's Avatar
New Member
Default If you take care of your car, you should never need a buffer...
Of course, my opinion may differ from others, but I strongly believe that if you care for your car regularly and keep a good protectant (wax or synthetic) on the car, you'll never need a buffer. There is more potential to damage the car with the buffer, especially for the novice.
I have a Pathfinder that I got new in 1993 that is completely swirl-free and the paint looks like it just came off the showroom - glossy and swirl free - and it's never seen the likes of a buffer.
Old Nov 10, 2003 | 12:07 PM
Troy H's Avatar
Default Hogwash. There are 1001 things that can harm the finish of a car not under your direct
control, unless you never drive the car out of your own driveway. A ROB like the 7424 not only does better work than what you can do by hand, it also does it faster. And assuming you're not a complete n00b, there's no danger in using the P-C.
Old Nov 13, 2003 | 05:35 AM
RickM's Avatar
AudiWorld Uber User
Default Agree. Maybe all he's ever done is wash and wax.
Because if you've ever applied a glaze or polish <i>correctly</i> by hand, you know it's a lot of work with the amount of elbow grease it requires. A PC makes it so much easier, and a bit faster too.
Old Nov 16, 2003 | 12:43 PM
mpwolf's Avatar
AudiWorld Expert
Bull$hit. Hand polishing will never acheive the finish of a good buffer.
 Pouria Savadkouei
 Michael S. Palmer
A8bil
Aug 16, 2014 12:36 PM
HiTEC
9
Mar 29, 2004 01:36 PM
Power5
19
Nov 18, 2002 07:58 PM
Silvr1.8T
Oct 14, 2001 10:23 AM
A4Eric
May 24, 2000 08:13 AM
