Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
Einszett Glanz Wax question
Old Jul 16, 2008 | 05:01 PM
trlyka's Avatar
Default Einszett Glanz Wax question
How often can you use this wax? Is it determined by the number of washes in between?
Also, what is In/Out spray? I looked on the DD site, but I didn't see it. Thanks
Old Jul 16, 2008 | 05:32 PM
detailersdomain's Avatar
Former Vendor
Default Adam's In and out will be back in stock at the end of July beginning of August.
As for Glanz you can top coat is once a month or every 2 months.
Old Jul 16, 2008 | 05:47 PM
trlyka's Avatar
Default Is that why I can't find it?
I was on your site and searched for it, but never found it. Can you provide a link for it so I can see what it is/does? Thanks
Old Jul 16, 2008 | 05:50 PM
Former Vendor
Default Re: Is that why I can't find it?
<ul><li><a href="http://forums.evolutionm.net/showthread.php?t=313835&amp;page=5">click here for an engine detail with in and out.</a></li></ul>
Old Jul 16, 2008 | 06:19 PM
trlyka's Avatar
Default Mystery solved!
Ok, so it's engine bay cleaner. I don't think I need that just yet, but when I do, I'll certainly get it. What a difference in the before/after. After you spray/scrub, can you use water to rinse?
Old Jul 16, 2008 | 06:21 PM
Former Vendor
Default Re: Mystery solved!
yes you use water to rinse.
on top I use P21S autowash to do the wheel wells, tires, bug and tar , etc.
Old Jul 16, 2008 | 06:24 PM
Kimchee's Avatar
Member
Default to my understanding the old In and Out was not VOC compliant... I'm assuming
they are reformulating it?
Old Jul 16, 2008 | 06:28 PM
trlyka's Avatar
Default Stop making me spend money! LOL
I'm trying to only order the wax for now, but it's tough. I may have to get car wash too....
Old Jul 16, 2008 | 07:01 PM
SilverThing's Avatar
Member
wow! "after" engine looks almost new - great, now I'll feel compelled to buy more stuff...
Old Jul 16, 2008 | 07:04 PM
Raistlin's Avatar
Default I have a ton of stuff that I bought from phil, in the beginning it hurts but once you have it
all you are good for a while. The Adams car wash is very good but if you are going to use Glanz wax, the einszett pearls or the new glanz car wash is also very good for the glanz wax finish. I have both the adams and the einszett car wash. You can also buy the maguiers gold class car wash from the local stores, that is a decent car wash.
I would definately pickup the Glanz wax and either one of the einszett car washes (pearls or the new glanz wash) and use that as your first wash and wax.
Then it is up to you if you need other things, definately get one of dd waffle weave drying towels, they are a thousand times better than anything else. As for detail spray, again the adams is very good, einszett also has one as well as menzerna. Also, the Maguiers quick detail at the local stores is decent. If you have stuff for tires use that, or pickup some adams vrt, works great on tires. Be careful on what tire cleaner you get, you can't go wrong with the p21s wheel gel.
