Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride
Has anyone removed light surface scratches/haze from the virtual cockpit LCD screen?
Old Jun 29, 2020 | 11:23 PM
Kevin Park's Avatar
Default Has anyone removed light surface scratches/haze from the virtual cockpit LCD screen?
Hey all, I have some light scratches on the LCD screen of the virtual cockpit. Most of the time it’s not noticeable but during the day when the screen is turned off you can definitely notice it in direct sunlight. Has anyone successfully removed the these light superficial scratches?
Old Jul 8, 2020 | 05:42 PM
Eradic8r's Avatar
I used to use a spray called Plexus that worked great on headlights and other plastic screens. I have seen a product called Novus for LCD but have never tried it. I have also read using rubbing alcohol and light pressure with a cotton ball may help. Obviously try at your own risk. This also has some good tips.
https://www.cnet.com/pictures/diy-sc...gic-and-myths/
Old Jul 17, 2020 | 09:05 AM
Dave_'s Avatar
On other vehicles I use a plastic polish (there are many to chose from on the market) with a very soft, small MF towel and buff dry after circularly rubbing the screen to remove light scratches. I can't speak specifically to the screen in your car, but that's how I clean up all others. The brands I use are Plast-X and Meguiars.
Old Jul 17, 2020 | 09:13 AM
bpp's Avatar
bpp
Default Paper towels
DO NOT use paper towels They are abrasive as hell on plastic surfaces and will in fact dull the surface more so. Any plastic polish, eyeglass cleaner/polish, should do the trick. After whatever fix is applied, use a damp microfiber to clean the surfaces. Beware of cotton ***** as they can be abrasive on plastic as well. Why not contact Audi for a solution? .02
Old Jul 17, 2020 | 09:16 AM
Dave_'s Avatar
What bpp said!
ITALSKIER
Oct 8, 2003 09:58 AM
TTigg
Mar 14, 2003 03:08 PM
YvesTT
Aug 7, 2000 02:02 AM
