- Audi How to Clean Engine Bay<br>Step by step instructions for do-it-yourself repairs.
How to clean engine bay...
Pressure washers are good for the really thick greasy stuff.
I've done this more than 40 and less than 100 times on at least five engines and only had to wait for one to dry out that I can remember...and I used a 2800 PSI pressure washer very liberally on that engine, a 1992 Audi I5 that had mold growing under the hood and in other places. Takes an hour or so to dry out unless you get out the hair dryer.
Using something like Vinylx on the hoses and plastic will make it shiny. The spotting I've seen is from left over dirt/grease deposits and not caused by the water.
On my car I use an air compressor to blow out the water out of the spark plug holes.
I usually wash the engine throughly before working on it and then shine it up with Vinylx after the job.
If it is really dusty-dirty I just hose it off if I feel like it.
<img src="http://www.gunk.com/cat_images/FEB1.JPG">
I did it on my car 2001 TTQC and it worked amazing i also did it on my friends 2001 S4 came out great also email me if you need more help!
Mike
Thanks,
Mike
But that was then. I was noticing in the wife's GTI the other day that it is entirely covered by a plastic piece, can't see the motor at all. All I do to "detail" her engine is dust and spray.
ugg... the thought of all that grease on my driveway
So I typically take off the top cover for the coil packs (on 12V 2.8) they are all in the center-front and hose it all down. I want to blast all the crap out of the spark plug holes before I change plugs, etc.
Why not just use compressed air? It creates static electricity (spark hazard) and just blows the crap around and not necessarily out of the engine bay. Getting the stuff wet means it will rinse and go to the bottom (ground) in my eyes.
As far as the air intake, I only have and work on stock cars. The air intakes on these cars are designed for wet weather. They are solid tubes with low, front facing openings. I would need to inject water under some really high pressure to overcome the gravity and turns in the pipes to even get the air filter wet much less penetrate the air filter and get water into the intake manifold.
One place where I show restraint on my car is where the AC evaporator drain is. I don't want to overwhelm it and get water inside the cabin.
<img src="http://pictureposter.audiworld.com/12414/enginedirt.jpg">
