Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
Rusting Rotors Solution..........
Old Sep 4, 2006 | 02:40 PM
4AudiQ's Avatar
Default Rusting Rotors Solution..........
Here is what my front rotors look like.......rust galore!
<img src="http://pictureposter.audiworld.com/81050/img_0950.jpg">
Into a plastic pan to remove the rust:
<img src="http://pictureposter.audiworld.com/81050/img_0951.jpg">
I ran across this stuff from a Google search. Non-toxic, biodegrable, earth friendly,
Evapo-rust. I bought 2 gallons at a local gun shop. He raved about the stuff. He does all his guns in it:
<img src="http://pictureposter.audiworld.com/81050/img_0952.jpg">
The hubs had some rust on them so, 000 Steel Wool, cleaned with alcohol to remove any residue,
studs taped off ready to paint(Dupli-Color High Heat 1200 degree flat black spray paint):
<img src="http://pictureposter.audiworld.com/81050/img_0953.jpg">
Rusty rotors submerged in the Evapo-Rust solution:
<img src="http://pictureposter.audiworld.com/81050/img_0954.jpg">
Rust all gone after just 1 hour. Rinsed with water and then air dried over night:
<img src="http://pictureposter.audiworld.com/81050/img_0955.jpg">
Hubs all painted:
<img src="http://pictureposter.audiworld.com/81050/img_0957.jpg">
Rear rotors are just as rusty:
<img src="http://pictureposter.audiworld.com/81050/img_0959.jpg">
Nickel Anti-Seize:
<img src="http://pictureposter.audiworld.com/81050/img_0960.jpg">
Putting Nickel Anti-Seize inside the rotor before I put it on the hub will prevent it from rusting to the hub, which just occurred on this forum by JXR on his 8-10-2006 post:
<img src="http://pictureposter.audiworld.com/81050/img_0961.jpg">
Anti-Seize goes on the back of each pad:
<img src="http://pictureposter.audiworld.com/81050/img_0962.jpg">
Front re-assembled:
<img src="http://pictureposter.audiworld.com/81050/img_0963.jpg">
Rear rotor rust removed and painted:
<img src="http://pictureposter.audiworld.com/81050/img_0964.jpg">
Rear rotor re-assembled:
<img src="http://pictureposter.audiworld.com/81050/img_0966.jpg">
Wheel back on and no rust visible through the spokes of the wheel:
<img src="http://pictureposter.audiworld.com/81050/img_0967.jpg">
I did this over a 3 day period. I am glad to get rid of the rust. Here is the link to Evapo-Rust.<ul><li><a href="http://www.evapo-rust.com/index.php">http://www.evapo-rust.com/index.php</a</li></ul>
Old Sep 4, 2006 | 05:49 PM
Press's Avatar
Fear the Miata!
nice job and great writeup...thanks
Old Sep 5, 2006 | 04:33 AM
ryoung's Avatar
Elder Member
1st class from start to finish.
Old Sep 19, 2006 | 08:04 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Adding to tech.
Old Oct 1, 2006 | 12:04 PM
audisrock's Avatar
Junior Member
Default Re: Rusting Rotors Solution..........
Neat.
You could also use the high temp silver.
Old Oct 13, 2006 | 08:48 PM
DVS27t's Avatar
Default FYI: according to the evapo-rust site, they NOW carry this stuff at autozones nationwide
i will be getting it tomorrow. did you clean the stuff first to get the brake dust off or did you just dump it in?
Old Oct 15, 2006 | 02:01 PM
4AudiQ's Avatar
Default I called 3 or 4 of my local Auto Zones and they told me........
they did not carry it nor could they get it.
I finally bought it at a local gun dealer, who by the way loves this stuff.
I even talked to the President of Evapo-rust and told him about my trying to buy the gallon size at Auto Zone.
Old Oct 15, 2006 | 02:03 PM
4AudiQ's Avatar
Default I just dumped the rotor in a pan of Evapo-rust and let it work.
Took about 1 hour.
I did wash it off after taking it out of the solution.
Old Oct 15, 2006 | 08:04 PM
DVS27t's Avatar
how much was the gallon? i bought some little ones
Old Oct 15, 2006 | 08:06 PM
DVS27t's Avatar
Default i have done my caliper carriers thus far. the stuff works great! good find.
i found a bin that will house my 345mm rotors so i am gonna dump em in tomorrow.
