Problems trying to re-code ABS module/steering angle sensor...
Old Jan 15, 2006 | 02:20 PM
4Bidden's Avatar
Default Problems trying to re-code ABS module/steering angle sensor...
After attempting some instructions found on this forum, I am still having problems coding the abs module. The software code stays all zero's and when I do the steering angle calibration, I get an error. Can someone please provide me with the correct login numbers as well as the software code for the ABS module? The car is an 02 Audi S4 (B5) w/ESP. We tried and tried but when we were able to get one code to stick, it would eventually revert back to zero's when you restart VAG. Thanks for any help. Some detailed instructions as to how to correctly do this would also be helpful.
Old Jan 15, 2006 | 05:11 PM
mod tech's Avatar
Default depends on a few things
if the control module part number is 4B0 907 389 then you can not code the module
If you can code your control module then
manual trans login code is 09495
auto trans login code is 09497
the code for manual s4 is 04395
the code for auto s4 is 04397
clear as mud?
if this does not work then give me an email or follow on this post
Old Jan 15, 2006 | 05:44 PM
4Bidden's Avatar
Thanks, I will definately give that a try.
Old Jan 16, 2006 | 02:31 PM
Itchy Foot's Avatar
New Member
Default So the log in is 04397 for 4Bidden's car, so what code to use to code it?
or does it code itself after a proper calibration is done?
Old Jan 20, 2006 | 11:43 AM
mod tech's Avatar
that is the code, the login is 09497
Old Jan 20, 2006 | 09:07 PM
Itchy Foot's Avatar
New Member
Default We followed these steps. But it still reads -900 plus degrees
I followed this link <A HREF="http://www.ross-tech.com/vag-com/cars/espcoding.html">http://www.ross-tech.com/vag-com/cars/espcoding.html</A> and followed the steps exactly...
<img src="http://i15.photobucket.com/albums/a367/Itchyfoot/steeringangle.jpg" alt="Image hosting by Photobucket">
<img src="http://i15.photobucket.com/albums/a367/Itchyfoot/notok.jpg" alt="Image hosting by Photobucket">
Old Jan 21, 2006 | 01:23 PM
audifirst's Avatar
Default Re: We followed these steps. But it still reads -900 plus degrees
Did you guys checked wiring to the steering wheel sensor , could be a wire be damaged, or perhaps the sensor is bad, and it needs to be replaced...
400runner
May 16, 2018 05:08 PM
The_Jerbel (Jordan)
Jul 4, 2007 04:03 PM
4Bidden
VAG-COM Discussion
Jan 18, 2006 12:56 AM
4Bidden
Jan 16, 2006 05:39 AM
Boston Driver
VAG-COM Discussion
Sep 21, 2005 06:15 PM
