Events Discussion Discussion forum for Audi events, shows and happenings
a6 2005 a/c problem
Old Jun 12, 2016 | 05:35 PM
Batran1's Avatar
Default a6 2005 a/c problem
Hellow guyz!
I have a/c problem my car is audi a6 2005
When I turn on the air condition everything looks ok except there is no cold blow air its just blowing air the same as out side temp.
I checked all fuses and all are working
There is no leakage ....
So I checked the a/c compressor there is no electric power reaching it, so I connected with electric power from other source to test it if its working or not, I can heir that it get engaged the sound like (tec tuk) but while doing that I opend my air con. But still there is no cold air blow ...
Guys help me to figure out my problem ....
Thanx in advance
Old Jun 12, 2016 | 06:13 PM
mlfox's Avatar
Your refrigerant level may be too low. The system likely has a low pressure cut off switch that prevents electrical power from reaching the a/c compressor clutch.
Regards,
mlfox
Old Jun 12, 2016 | 07:40 PM
raj99's Avatar
Tech Guru
Tech Guru
Originally Posted by Batran1
Hellow guyz!
Thanx in advance
Post in the C6 sub forum and you'll get some assistance on this issue... Not here on the event sub.
qsx010203
May 19, 2016 11:43 AM
jpnwdc
Q5/SQ5 MKI (8R) Discussion
May 18, 2016 10:30 PM
iamrph
May 16, 2016 03:32 AM
trevakaed
Audi A3 / S3 / RS 3 MKII
May 14, 2016 07:19 AM
