Feedback Need help with a Forums feature, noticed a broken link (or other site problem) or just have a general question - this is the spot
Any updates on when the apostrophes will stop causing text errors?
Old Oct 3, 2005 | 07:13 AM
Longwolf (Christian)'s Avatar
Default Any updates on when the apostrophes will stop causing text errors?
I just posted 4 min ago, and it is still causing text errors when the software sees apostrophes
Old Oct 3, 2005 | 07:20 AM
s4wood's Avatar
AudiWorld Expert
Default When the golf cart crashed..it caused it
Glad you are still alive...I missed the end of the race..did Biela/Pirro win?
Old Oct 3, 2005 | 11:17 AM
Johannes Erdfelt's Avatar
Member
Default When I have a way of reproducing it
None of my Windows machines reproduce the problem with IE or Firefox.
Once I get a way to reproduce it, then it'll be easy to fix, but until them, I'm clueless what the actual problem is.
Old Oct 3, 2005 | 01:33 PM
Strange. Happens when I post from work or home.
Old Oct 3, 2005 | 07:59 PM
mike*green's Avatar
Does it happen when you's post from work or home or both's?
Old Oct 5, 2005 | 11:35 AM
mdwsta4â„¢uroslut's Avatar
Member
Default anytime i write something with MS word then copy and paste it onto AW
apostrophes are always messed up.
Old Oct 5, 2005 | 02:16 PM
Member
Default Aha, maybe this is the problem
I don't have MS Office at home, so I had to try cutting and pasting differently.
I do have MS Office at work, so I'll give it a try there.
Thanks!
Old Oct 6, 2005 | 02:01 PM
SilverTQ's Avatar
Default like this example?
<ul><li><a href="https://forums.audiworld.com/test/msgs/5374.phtml">can be annoying</a></li></ul>
Old Oct 8, 2005 | 05:40 PM
Member
Default Not really a post that has the problem...
The steps I would need to do to reproduce the problem myself. I think I have it now, so a fix should be coming soon.
Old Oct 11, 2005 | 05:35 PM
Member
Default Ok, this should be all fixed now
Thanks to A2TURBO for the pointer on how to reproduce it.
