Feedback Need help with a Forums feature, noticed a broken link (or other site problem) or just have a general question - this is the spot
Audiworld Malware Solution.
Old Jan 11, 2004 | 11:00 AM
Cameron's Avatar
AudiWorld Uber User
Default Audiworld Malware Solution.
My browser is (finally) healthy again.
For others, if you find unusual URL's being posted on Audiworld when you post a message, follow this procedure. It worked for me but, obviously, may not work for you if your problem is not exactly the same.
Go to c:\windows\downloaded program files\
Look for a file with unknown author and unknown creation date. On mine, there were two files, both suspicious, probably duplicates or near-relatives of one another. One was IE Explore 101 and one was 1010101-01. The "version" field of both showed up as 1010101... etc. so that is probably the easiest way to identify this problem.
Right click and remove these program files.
Then clear your cookies and clear your cache.
Then restart, get on the internet, and try to post.
I still have been unable to determine exactly where this problem came from.
Thanks to AWOT and individuals who emailed and helped diagnose this problem.
Old Jan 11, 2004 | 02:15 PM
CGTBrad's Avatar
Default The beast is spreading.
<ul><li><a href="https://forums.audiworld.com/4000/msgs/47123.phtml">https://forums.audiworld.com/4000/msgs/47123.phtml</a</li></ul>
Old Jan 11, 2004 | 02:56 PM
MFZERO's Avatar
happens a lot with AIM users as well
Old Jan 11, 2004 | 03:39 PM
AndrewsQuattros's Avatar
Default usuallly on AIM if you....
click the broser where you got the Virus from again, there will be a hard to see link that says "Click Here to Remove!" or something like that. Follow the steps and it gets rid of it all. Still though freggin bastards who do that !!!
Old Jan 11, 2004 | 03:56 PM
Jason Teller's Avatar
AudiWorld Founder
Default I'm glad it was solved
I'll be really glad when more people can make the "fix" work too.
Old Jan 11, 2004 | 08:21 PM
1.8TQ99.5's Avatar
25 Year Member
Did you happen to keep a copy of the virus? I'd be curious to check it out.
Old Jan 12, 2004 | 06:47 AM
GusS's Avatar
Member
Default Here's what I have
In C:\Windows\Downloaded Program Files
Type: ActiveX Control
Codebase: mhtml:file://C:NO_SUCH_MHT.MHT!http://www.008k.com/partner/inst/f22776.exe<ul><li><a href="http://www.allofporn.com/">http://www.allofporn.com/</a</li></ul>
Old Jan 12, 2004 | 11:47 AM
1.8TQ99.5's Avatar
25 Year Member
Default Here is some more info on this malware
<ul><li><a href="http://www.computing.net/security/wwwboard/forum/8346.html">AW is not alone...</a></li></ul>
Old Jan 12, 2004 | 03:04 PM
GusS's Avatar
Member
cameron's solution works. cwshredder doesn't
Old Jan 14, 2004 | 12:02 PM
silver rain's Avatar
Default i have this porblem and have treid your solution as well as others and i can't fix it!!
what should i do! i did have those strange files in that folder but even after i deleted them the problem is still there!<ul><li><a href="http://www.xswingertreff.com/Dean/">http://www.xswingertreff.com/Dean/</a</li></ul>
