Scratch
I have heard that Scratch-X is a good product for fine scratches. Should I use this product?
What do you guys recommend?
<img src="http://pictureposter.audiworld.com/91403/scratch.1.jpg">
Start with mild (cleaner wax or windex) and work your way up to scratch remover, compound etc. Then once the scratch is out, work your way back down to polish to get any haze out.
Not to mention you will now have one spot on the car entirely devoid of orange peel which will stand out almost as bad as the scratch.
If the scratch is deep enough, then you may have to level the paint with wet sanding and compounding- but that should always be a last resort option as you run the risk of either burning through the clear or causing premature failure due to overly thin film thickness.
IMO, the latter option should be left up to a reputable shop- not a detailer or weekend warrior.
