Anyone using Cat Cams
Old Nov 6, 2004 | 12:07 PM
elijahallen's Avatar
Default Anyone using Cat Cams
<center><img src="http://pictureposter.audiworld.com/71531/p1010189_1136_x_852.jpg"></center><p>Hi, I have had a set of Cat Cams for over a year and am thinking about installing them. They have adjustible cam gears and an adjustible exhaust pulley. Is there anyone on this list running these or have experiance with installing them. I live in Michigan but would travel if there was a shop that could do the job and some custom tuning. Anyone? Thanks,
Elijah
Old Nov 6, 2004 | 01:58 PM
AntiSocial's Avatar
Default Cams are good.
While the motor's off the car, check piston to valve clearances.
Old Nov 6, 2004 | 02:31 PM
Stage-3-Emre's Avatar
Is that a gear at the end of the intake cam?
Old Nov 6, 2004 | 04:40 PM
ddg=shinebox racing's Avatar
Default 20v's are setup like the VW 16v...
The exhaust cam is turned by a toothed belt (like the 10v engine) and the intake cam is turned by a chain driven off the exhaust cam!
Old Nov 6, 2004 | 08:35 PM
KungFu4point2's Avatar
New Member
Default Javad got insane extra torque with stock 7a cams compared to CAT
check it out on motorgeek.com
Old Nov 6, 2004 | 08:46 PM
audifreakjim's Avatar
25 Year Member
Default Yea, if you're using hydro lifters, stick with OEM cams
If you're going to rev the **** out of it, like 8000 rpms, then solid lifters and hot cams should be a real good time.
Old Nov 6, 2004 | 09:21 PM
wurldpeace's Avatar
Default only heresay but only positive...
ive heard good reviews in general of cat.
i did a lot of cam talking when the loathsome blaufergnugen folk stuck me with a bad cam. i could rant Furiously but i know youre friendly w/them &amp; will respect boundaries.
through my plight i found webcam (steve) to be most very helpful. he has a wealth of knowledge in specifically camshafts. he is also the one who analyzed my cam &amp; found there to be improper base circle runoff that blaufergnugen played off with standard lines that did nothing but inspire me to find a lawyer to spend more money than its worth just to ...nevermind , i wont stop.
anyway, webcam is great but theyre in cali... but i trust their packaging abilities. the beat cam still sits safely through mailing 5 times and a home move.
the choice is yours, hope it all works for the best
Old Nov 7, 2004 | 04:23 AM
Default Ok, thanks for the reply's....
I will probably try to get these in by the spring. The AAN'd coupe is just about finished as far as the engine being put in and 6 speed mounted so the next step will be to mount the tubular header and figure out a good exhaust setup, at this time I will get the cams mounted and start begging Mihnea for some special tuning. Hopefully by next spring I will have one hell of a monster coupe to learn how to drive.
Elijah
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 7, 2004 | 05:10 PM
Default LOL, I should have been more clear... I meant at the OTHER end of the cam.
The 20vT 3B and 7A uses that gear to turn the distributor, but on AAN/ABY/ADU engines the gear is not on the intake came because they don't use a distributor.. Although VERY few (mine) early AAN's had a cam driven cam position sensor.
Old Nov 8, 2004 | 05:18 PM
Toxcheap's Avatar
I second that check out Javad's posts and dyno's on motorgeek.com
CrookedToad
Sep 15, 2014 02:32 PM
Sir Shnike
Nov 4, 2011 08:32 AM
javanator
Oct 13, 2008 10:39 AM
greenbird
Feb 10, 2008 10:26 AM
GregPac
12v V6 Discussion
Aug 2, 2003 12:28 PM
