1988 5000S Problems
Old Apr 10, 2001 | 05:07 AM
LoveToDrive's Avatar
New Member
Default 1988 5000S Problems
We bought this car new and I have driven it over 150,000 miles. Yesterday, I drove the car 45 miles, parked it; no problems. Five hours later, I started the car, drove 42 miles, stopped at a red light and the car shut off. I turned the a/c and radio off, re-started the car and proceeded through the light. The car shut off again. This happened MULTIPLE times. Each time the car would start up but it took longer and longer each time. The engine turned strong (never any indication that the battery was dying, too), the heat/temp gauge never passed midway, gas tank 3/4 full but the tach would jump from 800 rpms to 3000rpms. Last night the car started fine, idled in our driveway for five minutes or so but I am afraid to drive it. Any ideas, anyone? Please.
Old Apr 10, 2001 | 06:06 AM
SteveAngry's Avatar
Default Changed the fuel pump/fuel relay/fuel filter lately?
Whats been done to the car maintainence wise lately? Plugs/wires/rotor/cap/etc?
Heres some other possible culprits(guesses):
differential pressure outside of tolerance
unequal fuel dispersion
idle setting/O2 sensor
pressure regulator diaphragm defective
fuel filter clogged
fuel pump going out
fuel relay/bad contact
****ty gas
HTH
Steve Ankney
88 5000
Holland, Michigan
Old Apr 10, 2001 | 09:16 AM
Evilclown's Avatar
AudiWorld Uber User
Do the fuel filter first, and run some techron through it.
Old Apr 11, 2001 | 08:38 AM
®ob's Avatar
Default A dirty filter isn't going to make his car stall out like that
Especially since it was running alright before.
I'd check the FP relay
Old Apr 11, 2001 | 09:49 PM
Evilclown's Avatar
AudiWorld Uber User
Good point.
Old Apr 12, 2001 | 10:14 AM
Stephen Clark's Avatar
Default Re: 1988 5000S Problems
I had a similar mysterious stalling problem with my car..turned out to be the fuel pump. Took forever to diagnose the problem; including leaving it with my mechanic to drive for a week.
Of course, it never failed for him.
Finally got so bad that it was no doubt the fuel pump. If yours has never been changed in 150K miles, it is likely the culprit.
Stephen Clark
89 100
Houston, Tx
Old Apr 15, 2001 | 05:42 PM
New Member
Default Fuel Pump Relay Location?????88 5000S
Many thanks to everyone who responded to my dilemna! In checking my file, the fuel pump was replaced roughly 9.000 miles ago. So, we replaced the fuel filter, the O2 sensor, bought the Techron BUT...can't find the fuel pump relay. The Haynes manual has proven useless. 1988 5000S-Fuel Pump Relay location? Note: The car only did this after it was thoroughly warm, driven 45 minutes. Short trips around town-no problems. Again, thanks!
BidgeeRoad
Oct 29, 2016 07:44 AM
duncanm
Jan 19, 2009 09:32 AM
AFdude83
16
May 27, 2008 04:45 PM
Bryce
12
Jul 11, 2003 11:05 PM
Paul99SE
Aug 6, 2000 12:59 PM
