1994 90CS Clear Corners?
Follow the link at the bottom to the clear corners listed on their site. They are $114.95 for a set.
As for the installation, it should be pretty straight forward. The stock corners are only held in by two clips, and I believe your owners manual should give instructions on how to remove them. If it doesn't let me know and I'll try and explain it. The new corners should then slide right back in.
Hope this helps you out.
Matt<ul><li><a href="http://www.audiquattroparts.com/Lights/hella_clear_side_markers.htm">Blaufergnugen site - clear corners</a></li></ul>
