4000 CSQ tail light panel HELP!
Old Jan 27, 2001 | 06:32 PM
ironbanger2's Avatar
New Member
Default 4000 CSQ tail light panel HELP!
I just bought a 87 4000 CSq, and the light/reflector panel on the trunk lid is broken.
I bought another trunk lid from a junkyard for $50, & the lock had been pried out. If it wasn't so badly damaged, I'd have just swapped lids.
I can't seem to find more than a couple of nuts or screws that hold the lights onto the lid - I think it's glued on.
What is the best way to get the light/relector panel off the lid without destroying it?
Old Jan 28, 2001 | 11:52 AM
SteveAngry's Avatar
Default Re: 4000 CSQ tail light panel HELP!
After you loosen all the bolts holding it on you have to carefully pry it off...very carefully/very slowly. Use a butterknife to cut/pry/scrape behind the lights. There is a sealant/goop under there that is used to keep water out...it's a real pain in the a$$. That goop is like superglue!
To practice, go to a junkyard and find any Audi with some tailights(side or middle light panel)and work on your technique there...
Also I have had a friend that used a blowdryer to heat up the goo as he removed the lights...I've never tried that personally...HTH.
Steve Ankney
88 5000
Michigan
jcboiz
Jan 14, 2010 06:50 AM
NyukNyuk
Mar 25, 2009 01:35 PM
BTT2003
May 11, 2004 10:29 AM
G8TTR
Jun 16, 2003 04:46 PM
80AUDIS
Dec 18, 2002 07:14 PM
