Audi 100 warm start problem
Old May 14, 2000 | 01:59 PM
T. Henry's Avatar
New Member
Default Audi 100 warm start problem
I've read through the all the audi 100 postings and didn't find anything relating to warm start problems. My Audi starts just fine in warm or cold weather, but after driving for even a short while, stopping and restarting causes the engine to almost die, gain some momentum, then almost die, gain some momentum,.... you get the picture. This happens about 5 or 6 times then something kicks in and it runs fine.. Any suggestions??<p>T. Henry
Old May 14, 2000 | 05:58 PM
Hans's Avatar
Member
Default Sounds like bad fuel, fuel sender, or may need new injector(s).
<p><a href="http://members.home.net/rhlouie/a4.htm"><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/Hanssig.jpg" BORDER=0></a>
Old May 14, 2000 | 06:14 PM
DaveN's Avatar
Junior Member
What year?
Old May 14, 2000 | 09:17 PM
GEISTFREUND's Avatar
New Member
Leaking injectors or fuel pump check valve!
Old May 15, 2000 | 07:30 PM
T. Henry's Avatar
New Member
Default Re: What year?
It's a 1989 Audi 100<p>T. Henry
Old May 17, 2000 | 06:22 AM
DaveN's Avatar
Junior Member
Default I've never worked on that injection system...
so I can't help with specifics, the injectors and check valve could be a problem, but I think they would be more of an issue on cold start, after the fuel system has had a chance to leak down. I have had strange start and idle problems caused by leaks in the crankcase vent lines (they run from the base of the block at the rear to the top of the engine, though a check valve, to the intake), and I think the 89 still used the leak prone rubber hoses.
Old May 17, 2000 | 08:11 PM
T. Henry's Avatar
New Member
Default Re: I've never worked on that injection system...
Dave,
Thanks for the info. I'll check it out & let you know if it helped.<p>T. Henry
Randolph
Feb 20, 2008 03:56 AM
pep-1972
Jul 30, 2007 10:34 AM
1atlantis
Audi 100 / A6 (C4 Platform)
Jul 14, 2005 12:40 PM
1atlantis
Nov 23, 2003 03:17 PM
tanglewood
Mar 18, 2003 09:22 PM
