Code 2112
The code means that the distributor is out of position or that the crank trigger is dead. It seems to be the only thing keeping my car from running. It may require getting out my spare ECU to solve it, in fact code 2112 is the only reason I have a spare ECU.
Todd W
My apologies if you already know this, but at least it is good information for those who don't.
Good luck,
Jimmy<ul><li><a href="http://pweb.netcom.com/~jkp.mail/index.html">Jimmy's Audi S4 Pages</a></li></ul>
On the 5KTQ the codes are cleared whe you turn off the engine. You have to crank for 5 seconds in order to get codes at all and then leave the ignition on while you trigger the test sequence. Code 2112 is the only code showing up, i.e. I get 2112 - retrigger sequence - and get 0000.
You're not serious about this code being status quo on a non-running engine are you? That is, that no matter why the car doesn't run this code will come up??? I have tried 2 ECU's and I am currently chasing the wiring. I think the sensor is OK, but I will check again just to be sure. I really need to buy an O-scope!!!
Todd W
Good luck!
Jimmy
You can smell gas in the tailpipe after a few cranking sessions, so the CIS must be working to some extent.
There isn't a whisper of a spark, but I don't have someone else around to crank it while I check for sure.
6 weeks ago before I pulled it apart it started right away after sitting for 4 weeks.
Everything seems to point back to the code.
argh!!!
Todd W
