Coolant Problem
Old May 16, 2000 | 05:17 PM
Ken H.'s Avatar
New Member
Default Coolant Problem
About 3 weeks ago the heater hose broke on my 84 Audi 5000, so I had to get it fixed. Since that time I have had to top off my overflow tank 2 times because my warning light is coming on. I know that this is a closed system and difficult to get enough coolant into the system through the overflow tank, but how many times does it take? I am not seeing any evidence of a water leak on my driveway and no water on the front floorboards. What should I do, just keep filling the tank or look for another problem?
Thanks in advance.
Old May 16, 2000 | 07:14 PM
Joseph V.'s Avatar
New Member
Default Re: Coolant Problem
You are making sure you don't overfill the coolant, right? Fill it to minimum when the coolant is cold.
The coolant could be accumulating somewhere under your hood, but not on the driveway. Check under the replaced heater hose, if I remember right, the fluid might accumulate in the chamber in front of the firewall (has the A/C, heater unit (and the infamous blower motor). You have to pop off that plasic cover (at least on my 85 5ks).
Old May 16, 2000 | 07:34 PM
Ken H.'s Avatar
New Member
I'll check under the hood. Thanks N.T.
Old May 17, 2000 | 06:57 AM
Todd W's Avatar
Junior Member
Default Run the heater.
You may have an air pocket in the heater core that is filling slowly.
Todd W
Old May 17, 2000 | 07:37 AM
DaveN's Avatar
Junior Member
Default I think this is likely...
but if it keeps up and your not seeing a leak check your oil, you might have a blown head gasket (which may blow into the cylinder so it might not show up in the oil).
Old May 17, 2000 | 09:09 AM
Ray Calvo's Avatar
Rest In Peace
Default Isn't there a vent valve in the coolant system?
My mind might be going, but I thought I remember one on my old '90 Coupe Quattro, up at highest point of (I think) heater hose before the firewall. Had to open it till coolant poured out while engine was running.
skim464
Jul 28, 2012 03:47 AM
SFexBOY
Feb 18, 2008 05:03 PM
absolutcq20v
Oct 3, 2005 11:03 AM
beep-beep
Audi 100 / A6 (C4 Platform)
10
Sep 29, 2005 12:41 PM
Blown Nogaro
9
Jul 15, 2003 06:02 PM
