Cooling system Problem
Old Jan 7, 2001 | 07:46 PM
  #11
Jack in FL's Avatar
AudiWorld Expert
that's a bit too close to differentiate... i have a 92 100... lol want me to join you guys? :-)
Old Jan 8, 2001 | 05:39 AM
  #12
92-100S's Avatar
New Member
Default Re: YOU COPYED MY NAME!!!!!!
I've had this name for at least 6-9 months : )
Old Jan 9, 2001 | 06:29 AM
  #13
jnormandeau(93100CSQuattro)'s Avatar
New Member
Default I'm having the same problem-- new questions
My "high speed' fan is always on, from dead cold starts.
I know this because when I remove the high speed relay switch(#217) the fans stop.
Question is can a bad relay cause the fan to be on all the time or is it the
radiator fan switch or either one?
( BTW: where are they located?) I think there are two of them.
Thanks.
Jim
Old Jan 9, 2001 | 08:55 AM
  #14
QCRAZY's Avatar
Default Sure, a relay could cause that....
...Is there another relay that you could swap to check?? You could also tap the relay to see if that will shut the fan off.
More often than not relays won't switch on. It's not as common for them to get stuck in the switched position...but still possible!!
HTH!!
Andrew
90 80q
91 90
95 90q
Old Jan 10, 2001 | 06:38 AM
  #15
New Member
Default UPDATE Found source of problem..Re: I'm having the same problem-- new questions
I unplugged the connection that leads to the "temperature switch" located on the lower left side (driver's side) of the radiator.
The fan does not come on. So it appears that I have a faulty/stuck on temp switch.
I not sure how these things work. Does anyone out there know? Can they be cleaned up to get working?
Also, when you remove it does all the coolant spill out or is it setup differently.
Thanks.
Jim
Old Jan 10, 2001 | 08:25 AM
  #16
ARK's Avatar
ARK
Radiator fan thermoswitches cannot be fixed, buy a new one. Coolant needs to be drained.
a6wag
Audi 100 / A6 (C4 Platform)
Nov 10, 2008 06:55 PM
HIS4
Jun 15, 2006 07:00 AM
AudiS4guy - NorCal
10
Feb 11, 2005 12:11 PM
Audi Junkie
17
Aug 6, 2003 08:03 PM
86CGTCE
Apr 24, 2002 08:10 AM
