Electrical drain
Old Dec 16, 2000 | 11:32 AM
Khris's Avatar
New Member
Default Electrical drain
I have a 92 100s, and it can drain a battery in about 4 hours while parked. I have checked the main wire to the starter junction, it is not the problem.
I then removed the 'other' two wires that lead to the fuse/relay panel. I could not find anything abnormal. However, when I put it all back together....it worked....for 2 weeks. Once again it is draining the battery at about 15 to 20 amps. There is no motor running, I have removed the stereo, and I dont hear humming. It would seem that 15 amps would weld a short together, so I dont know why it would be intermittent.
I am curious as to how the "over voltage relay" works? Could it be stuck open and draining off power? Has anyone else experienced this problem?
Thanks in advance for any help,
Khris
Old Dec 16, 2000 | 01:51 PM
Khris's Avatar
New Member
Default Re: Electrical drain
Proper name of relay is: Load Reduction Relay.
What does this do? And if it were to fail, what would happen?
Khris
Old Dec 16, 2000 | 06:01 PM
mel g's Avatar
Default load reduction relay: removes elecrical power to certain accessories during the few seconds that...
the starter operates. Purpose is to ensure the battery can give its full effort to the starter motor.
But as far as the current leak, 15 amps really isnt all that much. you could weld something with that if it were small. but any reasonable 12V switch can handle that- a headlight or blower motor could use around that amount.
Your problem is to locate the intermittent current leak. By process of elimination, tediously disconnect one thing after another, remove fuses, etc, until you locate the current drain. Could be as innocent as a cig. lighter stuck on.
You can find it, good luck
Old Dec 17, 2000 | 11:49 AM
Khris's Avatar
New Member
Turns out there is water getting in by the upper relay box. I need to seal the area, and it should all work again. So far so good with it dry.
On a happy note, I also fixed the ABS.....it was the fuse on the relay in the kick panel
735-993-a4
Aug 23, 2021 05:30 AM
Lucas Larson
Feb 27, 2020 09:37 AM
ErikS4
Jul 7, 2007 05:28 PM
Aussieguy
Jan 11, 2003 10:41 PM
monkeyaudi
Jun 18, 2002 02:20 PM
