Engine vibrations on the peddles (normal??)
Old May 18, 2001 | 09:34 AM
KLALE's Avatar
Default Engine vibrations on the peddles (normal??)
I don't know if it's me or am I just paranoid, but when I drive my 93 90s (manual trans) I feel engine vibrations on my peddles. However, one day when the outside temperature reached 85+, the engine vibration decreased substantially. The ride was so smooth. Is this typical, is something wrong or am I imagining things!
Old May 18, 2001 | 11:56 AM
®ob's Avatar
Could have a motor/trans mount failing
Old May 18, 2001 | 03:29 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Well..............
Harmonic vibrations are not uncommon with Front wheel drive cars. Especially Audi's!
Could be any number of items causing the vibe's to transmit through to your pedals.
Has you car ever been in an accident?
Transmission mounts, and motor mounts are the usual suspects. Or loose suspension sub frame
bushings & bolts.
Unless it get's worse, I wouldnt worry too much about it. Being a 1993, you Audi has its fair share of normal wear & tear.
Old May 18, 2001 | 04:27 PM
KLALE's Avatar
Default Re: Well..............
Since I've purchased the car it has seen 3 different mechanics. All of whom say the motor mounts and trans mounts look good. I was also informed the bushings are in good condition as well. You are correct about the wear and tear. The car has 140K worth.
Accidents? I don't think so. My mechanic would have informed me of that kind of problem.
Anyway, The vibrations aren't bad enough to cause concern. I just thought it interesting, the ride got better when it got warmer outside. And like you said, it could be caused by a number of things. For all I know the vibrations I am feeling could be from the road. I had some KYB shocks and struts installed (man are they stiff, I feel every thing).
Do you know which aftermarket shock will give me my smooth ride back, so I won't feel every nook in the road?
Thank for the info. miktip
Old May 18, 2001 | 04:28 PM
KLALE's Avatar
Default Re: Could have a motor/trans mount failing
I had those check. Their fine.
Old May 18, 2001 | 04:56 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Some like Boge's. OEM from the factory.
Old May 19, 2001 | 08:28 AM
Kev90S's Avatar
New Member
Bilstien will be a little stiff if you are going for the smooth ride.
Old May 21, 2001 | 06:17 AM
KLALE's Avatar
Thanks for the Bilstien infomation. That was going to my next question.
jared kane
Sep 4, 2007 06:03 PM
gimik
Jan 19, 2007 10:49 AM
Double Barrel (Karl)
Florida Discussion
Nov 28, 2006 02:42 AM
S4orce2001
Feb 5, 2004 04:33 AM
Mr.D-'97 A4q 12v
12v V6 Discussion
14
Nov 10, 2003 02:00 PM
