Engine won't start
Old Jun 13, 2000 | 06:19 PM
chknwng's Avatar
New Member
Default Engine won't start
I just replaced the fuel line that runs from the fuel pump into the engine. I asked a few mechanics about it and they told me to keep crankin it up! I did that for an entire day. I'm getting fuel all the way up to the Fuel distributor(1987 5000s) But no fuel is coming out of the injectors. I'm assuming that my sensor valve isn't quite set properly. Any advice?
Old Jun 13, 2000 | 08:06 PM
Todd W's Avatar
Junior Member
Default Try starter fluid.
Pull off some readily accessible hose, even the PCV, and give a solid 1 second blast of starter fluid. Stick it back together and try to start the engine with the throttle cracked. Go ahead and rev it up to 3K if it starts.
If it starts but won't idle then you have a vacuum leak or problems with the sensor plate. If it gives you no more problems then you just had air in the injector lines. Does it catch at all when you crank it now, maybe just after hitting the starter?<p>Todd W
Old Jun 14, 2000 | 09:24 AM
chknwng's Avatar
New Member
Default Re: Try starter fluid.
I tried that already. I puulled the injectors out and no gas is being let out. I can't imagine a sensor plate problem. It was running fine until I changed the fuel return line!
Old Jun 14, 2000 | 10:05 AM
Todd W's Avatar
Junior Member
Default What happened when you tried it?
<p>Todd W
Old Jun 14, 2000 | 02:09 PM
audimoose's Avatar
Default Make sure that your rubber boot...
is not leaking vacuum. If its not clamped in perfect and tight, you'll have a HUGE vacuum leak and a non-starting car. Did you move it all when changing the fuel line?
Marty H
1986 5000S Avant
My 4th Type 44
Old Jun 16, 2000 | 11:51 AM
GEISTFREUND's Avatar
New Member
BTDT. Listen to Marty, check the boot !!
Old Apr 6, 2003 | 09:21 PM
audi4vr's Avatar
New Member
Default Re: Engine won't start
Have exactly the same problem, no start, no fuel at the injectors.There is fuel at the connection of fuel distributor from fuel filter. Did you finally figured out what the problem was???
Your help would be appreciated.
874kkid
Sep 23, 2010 10:18 AM
SparTTan
Jan 7, 2008 11:05 AM
heavyiron
Oct 7, 2004 05:44 PM
audinatic
Nov 17, 2003 01:11 PM
Byblos
Nov 20, 2002 03:14 AM
