GRRRinding Brakes!
Old Oct 17, 2000 | 01:44 PM
89-200TQ's Avatar
New Member
Default GRRRinding Brakes!
Began as minor grinding upon depression and then began to grind loudly and continuosly, even without brake applied, in forward and reverse (problem is only in rear, passenger side). No evident loss of braking power. Quits at over 20mph--under that, it seems like I'm going to lose the entire rear-end. Well, it's obviously parked and will go in shop tomorrow. Any ideas on what we're looking at? (89 200TQ w/ABS--153k, purchased at 151k).
Thanks!
Old Oct 17, 2000 | 02:54 PM
QCRAZY's Avatar
I would say that the "slide" guides on your caliper(s) are siezed!!!
Old Oct 17, 2000 | 08:26 PM
SteveAngry's Avatar
Default I agree...
it's probably the calipers...but just in case...
...I had this happen once to me and it turned out to be a bad wheel bearing...apparently it had caused the wheel to rotate off axis and grind aganist the brakes...so keep that in mind if the calipers turn out not to be the culprit...hth
Steve Ankney
Old Jan 3, 2001 | 05:55 PM
89-200TQ's Avatar
New Member
Default Re: GRRRinding Brakes!
Yep, that's what it was!!
tx170754
Nov 6, 2007 09:28 AM
XcellR8edAudi
12
Aug 4, 2004 01:06 PM
Mike Damberger
Misc. Models Discussion
Jan 15, 2001 03:50 AM
