Headlight washers stopped working...
Old Feb 5, 2001 | 11:42 AM
sidespar's Avatar
Default Headlight washers stopped working...
they just stopped. What's the problem. They used to work? Maybe the line came loose (this happens with regular washers all the time) if so, how do i get to it? the tank has fluid in it and everything
Old Feb 5, 2001 | 02:15 PM
QCRAZY's Avatar
Do you have your headlights on????
Old Feb 6, 2001 | 11:55 AM
sidespar's Avatar
Default Yes, but it still dosen't work
they actually used to work no matter whether the lights were on or not, now they just don't work at all.
Old Feb 6, 2001 | 03:20 PM
QCRAZY's Avatar
You got me....is frozen lines a possibilty?? (I've had that twice this winter)
Old Feb 6, 2001 | 08:48 PM
Seattle Scott's Avatar
Check your fuses????
Old Feb 7, 2001 | 11:55 AM
sidespar's Avatar
Nah, i don't know what's wrong, what about the fuses -i didn't know they were controlled with a fuse
Old Feb 7, 2001 | 03:22 PM
QCRAZY's Avatar
Default There not...
..controlled by any fuses. But I wonder if the relay went out. It's relay #4 under the hood!! Give the relay a flick or two, then flip your headlights on and see if you get anything.
If that doesn't work you could also try a jumper wires from terminal 19 to 21 (at relay #4). Don't get sprayed!!
Good Luck!!
Andrew
90 80q
91 90
95 90q
Old Feb 7, 2001 | 05:28 PM
kevster's Avatar
New Member
Default The Pump?
I had to replace the pump on my 93 90S at about 68k miles. If the problem is not the relay, I would suggest checking the voltage at the pump, which is at the bottom of the resevoir on my car. You can use either a multimeter or a test light.
wallabeex
Nov 3, 2021 04:06 PM
DudeDah
Dec 17, 2005 10:43 PM
DON2.0T
Aug 21, 2005 10:25 AM
UberVier
Jun 12, 2005 02:04 PM
90cqer
Oct 3, 2002 11:03 AM
