Help with changing pads, please!
Old Mar 28, 2000 | 08:00 PM
Sean T's Avatar
New Member
Default Help with changing pads, please!
Puuuuhleaze.....
Someone tell me how to get the piston backed up into the cylinder so
I can swing the calipers down and finish this install!
I installed the new discs and pads, but the piston is preventing me from
finishing. The picture in the bentley shows a special tool, but there
has got to be another way.
I really need your (everybody's) help!
It's an 86 CGT, email if you need more info!!
TIA,
Sean
86 CGT
99 A41.8TQ
Old Mar 29, 2000 | 11:11 AM
Todd W's Avatar
Junior Member
Default C-clamp or 2x4
You can squeeze it back in with a C-clamp, or pry it back in with the end of a 2x4. Be careful and don't get it askew. The rears are a completely different issue, but I think the CGT has rear drums. Also, don't put any load on the flex line while you are doing this. Don't even let the caliper hang from it.
There is also a cheap tool that will push them back in, not Audi specific.
Todd W
Old Apr 1, 2000 | 09:06 PM
Ray Calvo's Avatar
Rest In Peace
Default Covered many times; check the archives
I purchased a special tool which both turns and compresses the piston. Have used this prob. about 4 times between A4 and old Coupe Quattro. Check the archives within the past 2 months; try a search for "brake" and "piston".
Key thing is pushing in HARD and turning at same time.
Old Apr 1, 2000 | 09:09 PM
Ray Calvo's Avatar
Rest In Peace
Default More: you talking about fronts or rears?
Rears - my advice holds.
Fronts: go along with Todd -large C-clamp does the trick.
Need the right tools to do the job right!
Old Apr 3, 2000 | 09:48 AM
Sean T's Avatar
New Member
Fronts, just used a c-clamp, worked great, bye bye shudder!
Old Aug 8, 2000 | 05:00 AM
URiginalQ's Avatar
Junior Member
Default Re: Help with changing pads, please!
<p>A4 2.8Q
APR chipped(Asphalt and Projectile Rocks chipped paint and windshield)
BBS Rims (Bare Bones Stock)
Lowered (Leak in rear tires)
Seneb
15
Jul 23, 2007 04:50 PM
MoralDK
May 4, 2004 05:15 AM
frankdome66us
Oct 30, 2003 01:17 PM
Brdman*
Jan 23, 2003 10:15 PM
trd_3000
Nov 7, 2002 07:44 PM
