How to clear DTC codes?
Old Feb 4, 2001 | 01:19 PM
Kossu's Avatar
New Member
Default How to clear DTC codes?
So car is ´93 90 and I did screw up causing error codes long time ago. Now I got sometimes check engine light going on. I can read codes but because my mistake can't find out which code is current problem. I checked 12.org pages and connected left side pins as told, but can't get codes cleared. So is there sertain step when these clear connectors should be connected? Or what I'm doing wrong?
Old Feb 4, 2001 | 01:25 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Check it out!
<ul><li><a href="http://www.12v.org">http://www.12v.org</a</li></ul>
Old Feb 4, 2001 | 01:59 PM
Kossu's Avatar
New Member
Default Re: Check it out!
Sorry miktip, I wasn't wery clear what I tried to ask. Ye, I've looked 12v.org pages. What I ment wast that should I clear codes right after gettinq 4444 code or in some other step? Or should I get codes cleared when ever I connect those 2 left-hand pins? Still no success to clear codes.
Old Feb 4, 2001 | 02:08 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default So, what is it exactly you are trying to do?
Normally you clear the codes after you have read the codes.
If you are unable to clear the codes, then usually the problem still exists.
Old Feb 4, 2001 | 02:23 PM
Kossu's Avatar
New Member
Default Re: So, what is it exactly you are trying to do?
I think that you are right. So I caused some codes misshandling connectors some time ago. And didn't clear memory then. So now while driving engine check light comes on sometimes and goes off again after some time. What I'm trying to do is figure out what causes that. but never tought of that maybe that failure hits while I'm reading or trying to clear data and that's why there is allways failure code(s).
Old Feb 4, 2001 | 04:02 PM
QCRAZY's Avatar
If your engine check light is still coming on then you still have a problem!!
Old Feb 5, 2001 | 08:53 AM
ARK's Avatar
ARK
Default Engine running, connect for 4 seconds,disconnect, DTCs will blink, connect 4 seconds, disconnect,mor
then 4444 (no codes set), connect for 4 seconds, disconnect, shut engine off. The old DTCs should be clear now. This is the procedure as I remember it.
aTOMic
VAG-COM Discussion
11
Jun 16, 2013 12:41 PM
RedBarchetta
VAG-COM Discussion
Apr 4, 2006 09:31 AM
crofTTy
Mar 25, 2006 08:55 AM
1bads4
May 6, 2004 07:47 PM
