Idle oscillation
Old Jul 10, 2000 | 08:04 AM
bennyb's Avatar
New Member
Default Idle oscillation
Has anyone experienced idle oscillation where the car will not idle smoothly but constantly idles up and down? When I turn on the A/C it smoothes out but then starts again. I checked for vacuum leaks and didn't see any. Has anyone experienced this?
Old Jul 10, 2000 | 11:42 AM
GEISTFREUND's Avatar
New Member
Default Re: Idle oscillation
Two possibilties:
1) Idle Stabilizer Valve is bad or sticking.
You can clean it using carb cleaner.
2) Bad or mis-adjusted idle switch. This switch should just make contact when the throttle is in idle position.
For a test, run the car with the electrical connector to the ISV unplugged. If the problem goes away, you'll know it's one of those two things.
Old Jul 10, 2000 | 12:41 PM
bennyb's Avatar
New Member
Default Here's what I found...
When I started it cold today, it ran and idled around 900 rpm with no oscillation. After a while when it was running for a while, the oscillation started. It would idle, but fluctuates over about a 50 rpm range 2 times every second. When I shut off the engine and re-started it, it would stall and not idle at all. I had to keep my foot on the throttle to keep it running.
Disconnecting the ISV electrical connector, the rpm increases and the oscillation is still there.
Disconnecting the idle switch, the idle increases even higher and the oscillation dissapears. I have tested the switch and the connection is good and I can hear it click when opening and closing the throttle.
Let me know if this indicates anything to you.
Old Jul 11, 2000 | 02:18 PM
New Member
Default Re: Here's what I found...
I had the same problem on my '85 5KS. It turned out to be the wires on the connector to the FOT/IDLE switch. They were broken inside the insulation under the rubber boot where they enter the back of the connector. Someone with a Bently manual can probably tell you what the reading across the conector terminals should be. My break was right at the connector....easy to find.
Good Luck
Old Jul 14, 2000 | 11:08 AM
Les's Avatar
Les
New Member
I have the same problem with my '87 5K. I'm new to Audis so can you please tell me where the ISV and idle swith are?
Old Jul 14, 2000 | 08:54 PM
New Member
The ISV is on top of the engine. It will have a hose or steel tube comming from the crankcase, and also an electrical connector going to it. The Idle switch is on top of the Intake Manifold and the Full Throttle switch is under the I.M. One electrical conn. serves both switches. The idle switch tells the computer when to regulate the idle. The ISV allows additional air to enter the intake manifold to adjust the air/fuel mixture.
If you need specific info, post it on this list.
Good Luck
Old Jul 18, 2000 | 06:27 PM
bennyb's Avatar
New Member
Default Have you solved your problem?
I still have the oscillation with mine. I disconnected the ISV electrical connection but the oscillation is stil there. I shorted the idle switch connections and the oscillation is there, unplugging the idle switch, it goes away but idles high. What did you find?
Nkugs90
Jan 28, 2006 02:14 PM
pureroundcircle
Nov 27, 2004 08:21 PM
cuatrokoop
12
Feb 8, 2004 05:35 PM
jackr67
Oct 22, 2003 11:20 AM
Randolph
Aug 4, 2003 07:22 PM
