irregular ideling at stops??
Old Nov 24, 2002 | 10:54 AM
Mr H's Avatar
New Member
Default irregular ideling at stops??
Can someone help me, I have a A4 1.8 standard 1995, the cars ideling dips up and down after slowing or stopping, it then idels normal untill I rev the motor again it dips and evens out again. This happens when the car is hot or cold but does get a bit worse if hot. It started when I connected a cone filter to the car, I removed and refit the standard filter but is still doing this.
Old Nov 26, 2002 | 01:34 PM
Evilclown's Avatar
AudiWorld Uber User
Default The ECU or MAF may be out of spec now.
You'll have to either take it to the dealer or find someone with a VAG tool to help you out.
Old Nov 26, 2002 | 02:56 PM
kmnphg's Avatar
Default Re: irregular ideling at stops??
Do the simple thing first, check all hoses and also clean ur idle air control valve.
Old Nov 30, 2002 | 06:29 PM
QCRAZY's Avatar
Probably just bumped a vacuum line loose!!
1 dott 8
17
Nov 10, 2006 09:51 AM
AlLueb
Audi 100 / A6 (C4 Platform)
10
Sep 1, 2003 07:50 AM
screwynewy
Aug 31, 2003 06:54 PM
BigMouse
Misc. Models Discussion
May 29, 2001 08:43 PM
Shahak
Jun 28, 1999 06:28 AM
