Ongoing hesitation problems continued...help!
Old May 21, 2000 | 01:32 PM
SteveAngry's Avatar
Default Ongoing hesitation problems continued...help!
This is a follow up to a previous post...
After replacing fuel injectors, spark plugs, cap and rotor, checking vacum leaks, O2 sensor and air sensor plate(all good)I still have hesitation upon start up(see previous post for more info)I am guessing that my next place to check is going to be in the fuel delivery system. Tom Serrago and a couple of others have suggested such things as fuel sender relays and such...but I am unsure how to check these and of thier locations(amateur mechanic)Any further info or ideas will be appreciated.
Thanks.
Steve Ankney
88 5ks
Old May 21, 2000 | 03:27 PM
Joseph V.'s Avatar
New Member
I have a gut feeling it is the tranny (if auto, mine is, same problem)
Old May 22, 2000 | 03:02 PM
Tom Serrago's Avatar
25 Year Member
Default Stephen, I'm in the amature mechanic ranks too. The fuel pressure regulator (accumulator) ...
is under the car near the rear wheel well. Follow the fuel lines back on passenger side and you can't miss it.
No BTDT yet but appears to be an easy remove/replace operation (I use a Haynes as a reference, and the removal/install looks easy).
In order to properly perform a check and test of the various fuel system components and operating pressures yourself, you will need a Bentley and special tools and/or measuring equipment.
Tom S.
Old May 22, 2000 | 05:29 PM
DaveN's Avatar
Junior Member
Default Be careful when you open the banjos...
it stays under pressure and sprays gas everywhere.
Old May 24, 2000 | 11:18 AM
SteveAngry's Avatar
Thanks Tom and Dave...
Chapel
Audi Original "S" Cars
47
Mar 17, 2009 04:55 AM
PitViper
Aug 5, 2007 04:51 AM
shovex
Jun 11, 2007 05:16 PM
Marvin11
Mar 25, 2004 04:13 PM
Aussieguy
Jan 31, 2003 09:43 PM
