Problems with 86 5kTQ
1.) cold start problem (runs fine when it's warm) spraying fuel into the intake helps..
2.) something seems to be draining the battery as it sits
3.) brake lights.... pedal halfway down and tail lights light up... press all the way down and they go off which also causes the computer to give the brake warning light
4.) reverse lights not working
I have a spare turn signal arm for the car as well... what size is the bolt to remove the steering wheel? Also, is there a good site online where I can order parts for this car?
To remove the steering wheel, you need a 15/16 socket.
Can't help with the rest of your question.
2-I hate to say it but they like to do that. Make sure your system is charging (~14V at the battery on idle), and check the condition of your battery contacts, they corrode on the inside, I like to take them off and just clean both the contacts and posts with sandpaper.
3-Sound like you need and new brake switch. Up under the dash in front of the pedal.
Good luck with it.
Hope this Helps,
Marty H
86 5KS Avant
87.5 5KS (rip)
88 5KS (rip)
91 100 (mom's)
