warning light
there is no reset that I have ever heard of, so I dont think it's that...
the only real "maintenence" promp for the brakes would be for the front pads getting thin, but has its own warning light...
It could be a faulty warning switch...
HTH
Steve Ankney
88 5k
Holland, MI
The second warning light blinks red and beeps when you first start the car. This could mean many things - low hydraulic fluid, low brake fluid or low hydraulic fuel pressure. It could be a problem with your brake bomb - an expensive thing to replace. It could even be bad hydraulic fluid lines or a bad power steering pump since an imbalance in pressure within the hydraulic lines sets the beeper off too. Make sure your fluids are topped up, both brake fluid (DOT 4 only) and hydraulic fluid (German fluid only, eg. Pentosin 7.1 or 11S). Hope this helps.
this light couldn't be more irritating. i've rebuilt the calipers and bled the brakes... hydro pressure is fine, brake fluid is full.
do the brakes have a temp warning? could that be doing it?
the brakes do tend to get really hot.
