That wasn't fun at all.
BTW, didn't notice any difference with the new hose. My top turbo pressure is still only 1.2 bar.
My power door locks no longer work. I have to press them all down manually. When I do this, some pop back up. Is the whole system toast or do I just have a vacuum leak somewhere? My cruise control also does not work. It used to be that when I pressed the cruise button, it would want to engage and I'd feel the gas pedal lock for a second but then it would release. Now it doesn't work at all. How do you access the blue canister in the driver's side fender?
Or do you hear nothing when you lock your drivers door? Does the passenger side power locks still work? That's a sign of a bad accuator in the drivers door. I was able to fix this in mine by reseting the rubber seal(in about 5 minutes)!!
I just worked on this on my '90 80Q. I'm not sure if a 5000 is the same but I can probably offer some advice as long as it's vacuum accuated!!
Andrew
90 80Q
91 90
95 90Q
Good Luck
Looking forward to your advice.
If you have the Bentley manual it has a great step by step process of how to troubleshoot the power door locks. If you have the manual try that first!!
Let me know!!
Andrew
90 80Q
91 90
95 90Q
