Weird problem....
My in-tank fuel pump went bad on me, so I replaced it today. now, it's getting fuel everywhere but through the injectors(the 'rocco is standard CIS, not CIS-E, for those keeping score). There's fuel running to the injector lines, it's just that the injectors aren't squirting. None of them. Not a drop. Not even a little bit. Bone dry. I think you get the idea. Any advice from a CIS expert would be greatly appreciated, not even the Bently manual on Bosch injection is being much help. It strikes me as bad pressure, but if anyone's seen this before, any and all help is greatly appreciated.
Second: I am not familiar with your fuel injection system, but are the injectors themselves turned on and off? I know on my car, the amount of fuel injected is controlled by how long the injectors are kept open. Maybe your injectors are not opening.
Hope this helps,
Dave
the airbox and lift the air flap - you should
feel the resistance - fuel pressure above the
plunger. If no resistance, bypass the fuel pump
relay, so you can hear the fuel pump running. Now
lift the air flap again. You should hear the
injectors spraying the fuel. If not, check, how
far towards the engine your fuel press. goes.
With fuel pump relay bypassed (pump running)
check line connections one-by one, how far is
the pressure. I hope you wil drive soon.
Maybe there is a fuse to protect the injectors from burning out if there is no fuel.
Good Luck
Sam,
