I caught the mod bug
Old Oct 13, 2008 | 03:40 PM
Jereme (re up)'s Avatar
Member
Default I caught the mod bug
After asking some questions on these forums about DIY mods and I decided to go for it. I did a few minor things this weekend. First I did the stealth tail lights then changed the spark plugs to copper tipped, changed the air filter and the final change was blacking out the front grille. The front grill looks amazing. I am so happy with the way it looks. I did not do the lower grille yet, because I am not sure how to get it off. Does anybody know? Also I got an air filter from Autozone and it was a different thickness then the audi one I took out. Will this be a problem? Length and width wise it was fine. Also washed me car which was fun. Now all I can think about is what I want to do next.
Im thinking
Blackout Lower grille
N249 bypass (I think I get how to do it)
BOV/DV I kinda want that woosh noise but not sure
thought/ideas?
will post pics tomorrow at work
Old Oct 13, 2008 | 03:41 PM
ScratchRob13's Avatar
Ha! where are you?... just follow the AZ writeup i posted.. it had tabs holding it in
Old Oct 13, 2008 | 03:44 PM
Default No BOV. End of discussion.
It will make your car run rich because it is metered air (MAF) and putting into the atmosphere will screw up how much air the ECU thinks it has... long story short... no BOV unless you need it. As in my setup where i have no MAF and no intake.
Old Oct 13, 2008 | 03:45 PM
EBG 18T [Eric]'s Avatar
i have a hyperboost diverter valve if you want one. I don't use it anymore...
Old Oct 13, 2008 | 03:47 PM
Default how much you want?
My cousin got chipped this summer, and he doesn't know about the stock DV failing...
Shoot me an email ScratchRob13 at hotmail dot com
Old Oct 13, 2008 | 03:53 PM
Member
yeah im interested how much do you want for it
Old Oct 13, 2008 | 04:06 PM
Member
Default ok
word I will look on AZ for it
Im in brookline.
I figured there were tabs I just ran out of daylight.
Old Oct 13, 2008 | 04:08 PM
SilverSchwinn's Avatar
Member
Default Remove your front license plate, then remove the 4 torx screws holding the plastic holder on...
once all that is off, just pull it out.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 13, 2008 | 05:10 PM
Member
ok cool thanks
Old Oct 13, 2008 | 07:14 PM
Mirror|rorriM's Avatar
AudiWorld Expert
Default I don't think you'll gain anything with an N249 delete, unless you plan on running a...
...stutter box as well.
You can get the whoosh noise if you get an open element intake. You can still run the stock DV that way.
