Anyone ever get one of these codes? (edited)
Agh.. Hopefully I never see it again.. 17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335-35-10--Intermittent
I ended up running the MBC in parallel with the N75 and its running pretty well (not as strong as it was went set for 21psi).. Its set for 19psi and shes not spiking anymore (which Im very VERY happy about).. Partial throttle applications are smoother with the N75 in there... I think Im going to try setting up the old URS4 N75 up with the MBC this way I can run 24psi without and issues from the ECU.. The car threw codes when I went above 20psi with the MBC..
Once I get the FMIC on the car, then the new N75 will also go on there, that will be the true test..
